P700 Badlands 5k winch ***INSTALL HELP REQUESTED***
jakes29
16
26
oklahoma
Has anyone installed this winch? Where did you mount your wiring under your hood?
KYhillbilly
KYhillbilly
553
1,663
Ashland, KY
I put one on my P500 but eventually replaced it with a Superwinch terra45. It worked fine but was noisy and slow. I ran dedicated wire to front and mounted the fuse and remote box to cross member close to dash.
jakes29
16
26
oklahoma
If anyone has installed this winch, I could use some help. Last thing I have to wire is the remote and switch. The manual says to tie into an ignition (presumably the acc plug) but the diagram shows the red wire running directly to the solenoid. Any help? Attached the instructions as well as a pic (prob confusing)
89344058 6F5F 412C 8B36 2E6ACC85E714 BCD46772 C917 4206 9762 DD9575A6F09D F45DDBF3 7343 4793 855F 7813EAC017BD
Homer
Homer
Happy Birthday MoPower!
1,242
16,024
GA
Pic is misleading. If you wire as shown, winch will always be hot. Wire to ACC for key on power activation.
