April 2019 got a new 700-4. December last year the battery was no longer holding a charge. Confirmed charging at 14.3 volts. One year later second battery is acting the same as the first. Again confirmed 14.3 volts charging. Drawing .017 volts when measured between - battery post and - cable. Takes about 5 days to drain if in the SXS or setting on the bench. First battery was stock, 2nd was a Chrome Pro iGel YTX14-BS. Any suggestions for a battery that will last a couple years in the great white north at temps below 0- +90 f?
Thanks
Thanks
