P500 Battery PaK added to back rack
Eltobgi
Eltobgi
4,599
15,187
North Dakota
If you live in a cold climate you should buy slightly larger batteries. Some manufactures provide higher capacity batteries for customers that are in cold climates.
I have not tried this but I have read that if your battery will not start the car in subfreezing temperatures, you can run the light or the wind shield wipers for a few minutes and that will actually warm the battery up and and help start it.
That doesn't sound like a stretch to me. I know as a battery is being charged at a high rate or being discharged at a high rate, they do get pretty hot.
I've never heard of the windshield wiper trick, but I've been in -50 degree temps near the Canadian border with a battery which would not turn the engine. If it works i will report back late January early February. Unless I wise up and move! Lol
Reactions: joeymt33
rocmar
rocmar
4,741
5,778
4 CORNERS
Still waiting for someone with
a pocket charger...to freeze
it...& see how it works...
The optimum temperature for a (lead acid) battery is 72 degrees. Batteries performance is diminished as the temperature goes above or below that increasingly. Lithium batteries like I use in my power tools seem not to be affected by temperature. The iPhone size 400 amp jumper that I have hasn't shown trouble with temperature variations, not sure what it is though.
I
These things are almost unbelievable. Have you tried it? I've seen the YouTube vids and I'm amazed.
ive got one of those and been very happy. It goes in the tool box for camping Side note do not try to start a diesel it'll fry the jumpers I've found out
Reactions: joeymt33
rocmar
rocmar
4,741
5,778
4 CORNERS
@rocmar definitely a cool product, but not really comparable to a dual battery setup. I own the Stanley by the way and it has worked well for years including cold weather starts. Air compressor will get you on your way. Cons-heavy, bulky.
I think you mistaken
mine is the 700
actually smaller than
a coffee maker
20160720 112407
I picked up this one by Stanley at SAMs club for $40. Haven't used it yet but claims to start a v8 engine, although I doubt it would turn my Powerstroke! Sunglasses are in the picture for size reference.
These are great for carrying on the Honda sxs's.
JCart
JCart
895
2,024
Kamloops, BC Canada.
Think the above is for lithium ion batteries down to about -17 degrees centigrade. Below that as far as I know they don't work at least one manufacturer noted that. I took the lithium ion battery back and credited it for a sealed lead acid as a second (battery) on my P5. Was kinda bummin as it had very powerful specs and it was teeny. Lead acid battery here in Canada, pulling lights on will only draw it down faster....
Reactions: joeymt33
I run the lithium iron rather then ion batteries in many of our vehicles but they absolutely hate being left in the cold for periods of time. If you start or use something a couple times a week it's fine however if left for more then a couple weeks they are junk. I found that out one year I replaced 7 lead batteries for them. That was a sad day. But they are 1/5 weight twice the power and drastically smaller. Perfect for a dirtbike or someone that doesn't ride winters. Lithium ion can be like that as well if left for too long.
Watch the little battery jump packs as they contain one of the two.
Sent from iPhone
Reactions: JCart
rocmar
rocmar
4,741
5,778
4 CORNERS
Yeah....
mines a 6 in 1
$50
Those small ones will freeze
don't leave it...in the cold.
...alot of guys showed there's awhile
back...saying they were good. I ask them to put
in freezer..then see.
Got no response...
rocmar
rocmar
4,741
5,778
4 CORNERS
Sent from iPhone
No so...
one good freeze...will
split them..wide open
...seen it...
Reactions: CumminsPusher
ehart814
ehart814
1,701
3,889
NWPA
No so...
...seen it...
Mine spent all of last winter (northwest PA) in my car. My car was always outside - not in a garage. My jump box did not split wide open, and it still works.
rocmar
rocmar
4,741
5,778
4 CORNERS
Something kept it warm
small batteries don't handle
the cold...
rocmar
rocmar
4,741
5,778
4 CORNERS
If It would of froze...
it would have split..
in utah...my Bros split
in his glovebox.
No so...
...seen it...
I agree with you but that happens when the voltage depletes and it freezes. As long as they are kept up they do ok. If not...I personally wouldn't run them in the winter. Take inside. It's fine for the bikes or something you don't plan on winter riding. They don't hold a charge as well in the winter as a lead battery. Period. Ride a couple times a week or trickle charge is ok. Most jump boxes use lead not lithium. The small ones all use lithium and shouldn't be left outside in the cold.
Reactions: rocmar
rocmar
rocmar
4,741
5,778
4 CORNERS
He never used it...
was in glovebox
I seen it....
so apparently it got colder there
...then where you are
.....my guess
rocmar
rocmar
4,741
5,778
4 CORNERS
My quad battery froze....
when I left it out....
small batteries not
effective if left in cold
....I believe they have
something that says
.....just that with product
He never used it...
was in glovebox
I seen it....
.....my guess
If it's never used then it's not kept up so yes that can happen and smaller batteries do take more of a hit. Lead is the best though at cold. I've got three semi 8d's in our bus, that's the biggest battery you can buy within reason and two are even deep cycles if they are not kept up they lose a lot of their usefulness over the winter if not kept up,two winters they will be dead and leaking. We added solar years back to eliminate the generator and that took care of that as long as snow doesn't sit too long this but can happen on any size. On our dirt-bikes with e-start we gave up and just replace them every spring with 15$ eBay gels and call it what it is. It was too hard to trickle charge all the time.
Sent from iPhone
Reactions: rocmar
rocmar
rocmar
4,741
5,778
4 CORNERS
Sent from iPhone
Pocket charger
...totally different
than wat I got...
I looked into alot
of alternatives...
Reading reviews...
price matching...
blah...blah
"Fat Max"
IMO
best buy
