P1000 Berzerkers
BigOL3
BigOL3
2,994
8,920
Anybody having an dry rot problem with Berzerkers . Mine are little over 1.5 yrs old, mileage between 1000-1500, 99% off road use. P1K stays in shop, out of sun, when not in use. I had a flat about 200' from the shop, so I ran it flat to the shop, over very soft pasture ground. After airing back up I found what I thought was a cut next to one of the 'side wall grips'. After closer inspection, I started noticing other cracks appearing next to many of the other 'side wall grips'. My tire repair guy put a patch in it and said it looked like dry rot to him, but the other cracks were just on the outside, but not all the way through. As of now, the patch is holding. I had planned a ride this week, so I will take my old stock tire/wheels along for insurance. I plan on checking with Berzerker since it seems to be BS to have dry rot so soon. The other 3 tires show no sign of dry rot.
61,013
Well, it took a while BUT Brazen came through and covered the dry root on warranty. They sent me a new tire and only as that I sent them back a piece of the sidewall, which I cut out and mailed back to them.
That's awesome O. Really cool they took care of you. Sounds like the others might need to dry rot too.... 😁
