P1000 Best location for horn button
Red21
150
487
sioux falls, sd
I will be installing a horn in my Pioneer 1000-5 to make it street legal. I am thinking of installing the horn button somewhere to the right of the steering column. I will use my dremel tool to cut the hole. Are there a bunch of wires anywhere behind the dash that I need to be aware of and avoid?
X
xmountaineer
23
72
WV
I have mine to the left of the steering column with the turn signals. I just used a utility knife to cut the holes.
39D2FD17 AB54 4C56 9C8B D06CF0B0A11F
115,290
There are a few but should be deep enough to avoid. Mine is in that area
Prntckt
Prntckt
1,092
7,608
Altoona, WI
  1. Talon X4
I originally had my horn button mounted in the lower dash area to the left of the steering column. If you’re careful it is an easy install. Just take your time and don’t rush it.
Reactions: Buggyman and Lady01
bumperm
bumperm
1,897
6,774
Gardnerville, NV
Likewise. Remove cupholder, easy wiring. More recently, changed th silver button out for a black one with blue backlight to match other switches. Horn is wired of Aux, always on . . . never can tell when you might be . . . naw, won't go there.
20211007 105941
0860silverado
954
1,834
louisiana
In the middle of the steering wheel😉
I want to upgrade mine to a setup like this. Can you tell us details? (Where you got the button, how to wire it without wire getting twisted etc?) Thanks! My button is currently between my steering column and my ignition switch. I'm tired of fumbling around for it in an emergency lol.
Reactions: Lady01
Red21
150
487
sioux falls, sd
Mine is a Corbin custom works complete horn kit with everything needed to install, including full instructions with pictures. It was right around $75.00
Reactions: Lady01
Y
Yakman
127
314
WA
I don't see one for a Pioneer on their page. Where did you find yours?
Reactions: Lady01
Red21
150
487
sioux falls, sd
Reactions: Lady01
322,690
Was this completely custom or can you purchase these components?
Steering wheel is just parts but to get horn working was custom. Wasn’t hard at all though. Just used a roller horn switch from old rig from wrecking yard. Ground a little to fit. Worked like a horn should
CB44C53A B1CD 4085 A825 F2495B48F3BE
1324DFA9 3C62 466F BEB3 DC14BD0144BC
767F4944 4C95 4910 8CDF B5B1CE08C5D2
bumperm
bumperm
1,897
6,774
Gardnerville, NV
For a small, self contained air horn that is very loud, I use this one: Horn
It's got a self contained compressor and twin horns, but still small enough to fit in a tight space. I mounted mine inboard of the front wheel on the fender support strut using a bit of rubber hose and a SS hose clamp. Worked great! (Though, due to its small size, it is higher pitched than a "truck horn". )
20211003 184434
Wellzy
Wellzy
269
900
SW Wisconsin
I am not a fan of drilling or carving into the stock dash, I just don't want to have an "ooops!" and need to repair it, or if I change something there is a left over hole.
I went with the center, so I can make my hole in the dash panel which I can replace, and the passengers have fun honking at the wildlife on the roads.
I don't think I would buy a horn kit when you can buy a horn and a button of your choice on Azon and do the wiring yourself if you have the know how. They are so easy to do!
Horn button is on upper left. I bought the Corbin Works turn signal kit and did not follow those instructions as I put the rockers in the center. I know it goes against how we drive a car but the blinker in the center is handy, I normally steer with my left hand anyway.
Dash
Reactions: Yakman and Lady01
