P1000 Best place to buy C-fab setup
aauman88
aauman88
1,091
2,846
Well I have decided to go with the C-fab front forward a arm kit with built in 3” lift, 15” wheels and 31” tires. Just looking for the best place to buy the C fab setup as I’m not on Facebook.
Thanks
EAE3A957 A464 4085 97AC 1D1B121D9DCE 62AF9C7D 6867 4C7F 99A3 CDB029044C81
BigRed7769
BigRed7769
405
547
Magnolia, Ar.
They r over priced and no more clearance that the superatv arms, yes I know what they claim but it's false and yes I've had both
Sent from my Moto Z (2) using Tapatalk
aauman88
aauman88
1,091
2,846
Wow ok I will definitely take that into consideration. Thanks. What is it that was wrong? Customer service, fit/finish or just didn’t hold up?
Definitely don’t want to spend that much and not be happy
BigRed7769
BigRed7769
405
547
Magnolia, Ar.
I bought cause was supposed to have more clearance than the superatv that I already had which was false. I measured before and after and gained nothing over what I had already with the superatv. When I called the owner he wasn't very nice and tried to tell me that the superatv stuff stretched my frame out and kept trying to assure me that his stuff was true and exact that my pioneer frame was the issue . I mite b some dumb but I'm definitely not plumb dumb! The customer service in my experience was a joke. I kept them on for a little bit cause was too lazy to change them back out and the squeaking little 1/2" heim joints drive me nuts, super loud and super annoying
Reactions: JTW
aauman88
aauman88
1,091
2,846
Thanks again. Is there another option for forward arched arms with 3” lift built in? I currently have 2” bracket lift but wanted lift built in arms of possible.
BigRed7769
BigRed7769
405
547
Magnolia, Ar.
No there isn't to my knowledge. I left my superatv bracket lift on when I put the cfabs on. It's says 3" lift built in but after suspension settled I gained nothing. I know a guy that has their arms on his with 30's and another guy with highlifter arms, bracket lift, and 28's and it has more clearance than the guy with cfab. I'd recommend the superatv arms or highlifter arms and the 814 shocks
T
tr20pat
11
9
south mississippi
I have 2018 pioneer 1000. I installed c fab arched arms with 3 inch lift 30 inch tires. Now can run over 5 gallon bucket with couple inches to spare. Wouldn't do that stock. Love them had no issues.
Reactions: Marcus77474
BigRed7769
BigRed7769
405
547
Magnolia, Ar.
Buddy of mine clears 5 gallon bucket just fine with superatv bracket lift, stock arms and 30" Intimidators
aauman88
aauman88
1,091
2,846
What shocks does he have? I have stock arms and bracket lift with 28” wheels and am not even close to clearing a bucket.
BigRed7769
BigRed7769
405
547
Magnolia, Ar.
Factory. What bracket lift u got?
aauman88
aauman88
1,091
2,846
Highlifter 2.5”. I know that’s 1/2” shorter and wheels are another 1” as far as lift but I’m not even close to clearing a bucket. Will measure next time out and see how close though for sure
BigRed7769
BigRed7769
405
547
Magnolia, Ar.
I know when I took the highlifter off mine and put the superatv on it made a huge difference
aauman88
aauman88
1,091
2,846
My apologies. I’m only about 1/2” from clearing bucket. Guess that extra 1 1/2” your buddy has does the job. Still wish I could get a arms with 3 or 4” lift built in so I could remove bracket lift. Guess portals would do the trick but damn that’s a lot of money
2BE7822A D384 4717 82E3 088B7B8184E2
aauman88
aauman88
1,091
2,846
I wanted to go ahead and get rims and tires ordered but am undecided now on lift/arm setup. How bad will the 31” Outback Max’s rub on the 1000 with just the 2.5” bracket lift? I have 1.5” spacers on rear, would spacing front out some help?
Just wondering if I could go ahead and get new wheels and then do the other when I decide.
Ok... let me start by asking what are you wanting to achieve here? SATV have a lifetime warranty and they’ve been good with any issues I’ve had with any products. I’m currently running a HL 2.5, fox shocks, SATV forward and rear arms and 30’s... I’m about to pull my lift and get it back with preload.
aauman88
aauman88
1,091
2,846
I’m happy with ride and performance just want a little extra ground clearance. The tires I have perform great so I was just going bigger size when I upgraded rims.
Kilo427
Kilo427
1,543
6,441
Cfabs have been wonderful and the customer service has as well on my end and I have abused them quite alot
aauman88
aauman88
1,091
2,846
I can’t get their site to work as far as ordering and I sent them an email Tuesday about how to order and haven’t received a response yet. Wheels will be here Tuesday so will see how they fit. If no answer from them by then will go different route if I need more lift.
