BRed Big red starting issues.
rasorbackqq
25
29
Springfield NS Canada
  1. Big Red
So noticed lately the big red at starting turns over a few times but not under full speed it seems. It always started . But drive it 10 minutes and stop turn off its not starting again. Seems like not enough power from battery. Try a few more times and it will start. Can hear a click with key turn. So 3 days ago it wasn't able to be started . Sat out side away from home for 3 days . I put the key in turned and it fires up. Drive it home park in garage . Try it yesterday and it started poorly again. Drive it 10 minutes and shouldn't have shut it off. After a few walking trips to the shop battery is at 12.65 volts and drops to 11.5 when key is turned . SXS has a second battery for the winch. I tried to jump it but still doesn't start. That battery is about the same .
So I drive my 500 foreman over to boost it . 14.3 volts when running and hook up the cables . Check the lines and 14.3 v heading to the starter but will not fire up.
So is it the batteries or the starter??. I haven't got to the starter yet as it buried under the passenger seat and the SXS not at home again.
Hello_Darkness
Hello_Darkness
666
2,678
Just to the right of nowhere
Big Reds are known for bad starters, Honda redesigned them due to this issue.
That's most likely the problem, if it has the post on the front of the starter instead of on top it's the older design.
rasorbackqq
25
29
  1. Big Red
Got it home . Fully charged battery . Still no so crank over . Got out the manual. Fooled around with it looking for the starter30 minutes to locate it . No info on net about them on the big red. Lots more under pinooeer models. Some say take out both seats and centre console . I see it better now then the flue hits . Order starter $108 on amazon.
Hit starter with a screwdriver doesn't start . tap a few more time and it starts. starts all the time now. Starter arrives . old one still working. Still sick with flue . No energy to work on it.
Keebler
Keebler
273
917
St Charles, Mo
The starter could have a bad spot on the commutator and when the brushes are on that spot there is no electrical contact, in which case it is just a matter of time until the starter stops in the bad position again. The other possibility is that the brushes were just stuck and vibration from working on the machine freed the brush. It is not uncommon that when a starter doesn't do anything tapping on it causes it to work again, however that is usually just a temporary fix, I would change the starter if it was mine.
rasorbackqq
25
29
  1. Big Red
So starter changed .
How we did it since there are no info. Remove passenger seat. bucket under seat and plastic around the ebrake and seat belt clickers. Look way down about 8" down . Took me about 30 minutes to find the starter. Last piece is the plastic running from side to side that houses the 12 volt aux port.
With that removed can see the back of starter with the dump box lifted
Now to the bolts for the starter. 10 MM and a 12 "extension 1/4 size. . One bolt is straight down and easy to loosen but don't drop it as its gone forever. Second bolt is under a rubber hose running there. Shove that over to left and push the socket on the 10mm bolt again. The 2 bolts have a washer system attaching them together with a clip on that hose. Now the starter will wiggle but not come out. So lift the box to see the starter Get something that can be hit hard to drive the starter out towards to the front of sxs. There is no room to swing a hammer in there. Hit it hard as it was 3 solid hits to free it.. After its free remove the 10 mm nut for the starter wire.
New one drop in the hole from top reattach the starter wire. Push the splined shaft into the starter hole . Its going to want to sit at an angle but it must be pushed hard to the motor . With a light the hole and how its sitting can be seen down through a small opening. Its was hard to come out and its just as hard to go in. We jambed the starter to the side with a flat bar and got a longer prybar in from a top front under the plastic and hoses. We aligned the pry bar in the V between the 2 starter attaching bolts and one person hammering and the other watching the progress and about 25 hits later the starter bolt holes were aligned with the threads. Repale bolts
Then we attached the battery and tested it . Success it started.
After I was done reinstalling everything I ended up with 4 bolts left . Not sure where they go. all 4 were the same as the bucket pan screws (12) but were a size smaller.
