Bluetooth speaker wiring
dthoma
Tennessee
I have a 2022 talon 1000r, I'm wanting to install 2 Pyle Bluetooth speakers.
Where do I tie into to get key on power ? Can't connect to battery because it will drain.
68,247
There are several spots under the hood.
The blue connector is one. We have a thingey to match in the club store.
dthoma
Tennessee
Thanks for the advise. I also have a winch to install. Do I run my hot and ground to the battery, or is there a spot to tie in under the hood ?
ScottJ24
ScottJ24
79
223
Cresson, TX
My 2021 Talon-R had a set of battery cables under the hood over the drivers foot well. They are taped togather and they will need to be connected back at the battery also.
Reactions: Hondasxs and dthoma
68,247
Yep....
There will be a large guage HOT wire for a winch near the blue plug, you will need to hook it up at the battery. Its hidden behind the battery. Taped up in Blue tape.
Also may be a ground wire too, They stopped adding this somewhere around that year. I think 2023 tho.
Reactions: BWAF and dthoma
