Evertime I get on a steep hill my brake pedal goes to the floor, no brakes. But 1 pump and back to normal. Has anyone had this problem and what would cause this to happen ? Kind of scary sometimes !!!!
That's dangerous, you probably have air in one or more brake lines. Go to the Honda shop and get some DOT 4 brake fluid (small bottle for dic brakes) and a small flexible tube that will fit the bleeder fitting on the caliper. Then check the level of brake fluid in the master cylinder, fill to the max level. Then get someone to pump the brakes, put the flexible hose on the bleeder fitting, loosen the bleeder fitting a couple turns, have your pumper pump the brake pedal and you watch for air, tighten the bleeder fitting and repeat on all the rest of the brake calipers, may take a couple of times. You can catch the flushed brake fluid in a clean container and just keep putting it back into the brake master cylinder for the rest of the purge. The bleeder fitting will be a fitting on the caliper with a rubber cap on it with no brake lines connected, you don't take it out! Just loosen it up couple turns. Whoops I didn't ask you if you knew how to bleed brakes.Keebler , the machine has been doing this since new, I have not touched it other than checking the fluid level. It is a 2020 with 130 miles on. I thought it would stop doing it because after the pedal goes to the floor the next time it has full pedal ???? Crazy !!!
Been doing this since new but you haven't taken it back to the dealer for a warranty repair?Keebler , the machine has been doing this since new, I have not touched it other than checking the fluid level. It is a 2020 with 130 miles on. I thought it would stop doing it because after the pedal goes to the floor the next time it has full pedal ???? Crazy !!!
I do know how just been a long time ago. I will give it a try asap. The only thing that has me concerned is it only happens when I have been on steap inclines , when I got home from deer camp just backing off the trailer caused it to loose the pedal ...... I plan to bleed the brakes and hope for the best. Thanks brother.That's dangerous, you probably have air in one or more brake lines. Go to the Honda shop and get some DOT 4 brake fluid (small bottle for dic brakes) and a small flexible tube that will fit the bleeder fitting on the caliper. Then check the level of brake fluid in the master cylinder, fill to the max level. Then get someone to pump the brakes, put the flexible hose on the bleeder fitting, loosen the bleeder fitting a couple turns, have your pumper pump the brake pedal and you watch for air, tighten the bleeder fitting and repeat on all the rest of the brake calipers, may take a couple of times. You can catch the flushed brake fluid in a clean container and just keep putting it back into the brake master cylinder for the rest of the purge. The bleeder fitting will be a fitting on the caliper with a rubber cap on it with no brake lines connected, you don't take it out! Just loosen it up couple turns. Whoops I didn't ask you if you knew how to bleed brakes.
That is what I think also,it is 2months out of warranty...... did not think I would have any problems with honda. Never have on my other machines.If it has been happening since new and you have that few hours I would contact Honda, it could be a bad master cylinder. The machine is new enough that Honda will handle it if it is still within warranty and might still handle if it is not under warranty as a good will repair. One more thought, if the brake is not spongy all the time it is probably not air, I am now leaning toward a master cylinder problem.
Do you have front a-arm guards?I do know how just been a long time ago. I will give it a try asap. The only thing that has me concerned is it only happens when I have been on steap inclines , when I got home from deer camp just backing off the trailer caused it to loose the pedal ...... I plan to bleed the brakes and hope for the best. Thanks brother.
