Building an aftermarket Dump Bed for your truck
104,850
Has anybody on here ever installed an aftermarket dump system onto the back of your truck? So far I’ve seen this company Pierce.
Light Duty and Medium Duty Dump Bed Kits
I’m considering this to use for hauling leaves I vacuum up with something like this.
DL1801VE Billy Goat Truckloader
Or for hauling soil and mulch. No gravel or anything to big. Especially since my truck is Aluminum.
It would negate the need to buy another truck or dump trailer which are $6000+
I’m just wondering about installation and usefulness and yalls most gracious thoughts on the matter...Tanks.
69,046
What are you going to do for your camper?
208,725
Have you done a soil test?
Reactions: 100Acre
But seriously.. buy you a decent old dump truck and a heavy trailer.. add a skid steer to your mini ex purchase and go make some money! Rather than just being toys they can be a write off and pay for themselves. Guys around here charge $100-125 an hour and stay booked. You can work as little or as much as you want on oddball jobs. And best yet... you can take some of those libtard’s money!
104,850
Tricycles mounted on each corner and use big U bolts to mount a sailing mast on the front. Not sure how to steer it though. Unless...
FFWD to 1:15
Reactions: Plumber32
104,850
104,850
I did a soil test years ago. But my soils are hard clay. I’m adding organic matter and recreating what nature does by layering and composting
104,850
Permaculture man...
There are a LOT of dump trailers along gulf coast for sale CHEAP they were used after hurricane Michael
Vikes79
Vikes79
SKOL!
11,684
113,346
South Dakota
  2. Talon X4 LV
FWIW I just rented a dump trailer that had a capacity of 4.5 tons for $70 a day.
I was able to move ~27 yards of gravel in about 6 hours and use the trailer to lay it around the driveway as I wanted to.
Yes I could have had it delivered for 150, but then I would have beat up my tractor loader moving it around.
I guess what I’m saying is just rent a trailer for a day or two. Much less expensive.
104,850
The system I wanna build. I already have clients lining up.
Reactions: CumminsPusher
lee
lee
Village Idiot
2,383
13,486
Springfield Ohio
Nobody has a dump bed kit?
I have neighbors with an old dump truck bed on an f-250 and one with a new dump trailer.
Really want to know how the in bed dump works.
Enquiring minds want to know.
104,850
Reactions: lee
sharp
sharp
3,757
14,955
Tennessee
I've used one of those vacuums for years. It was mounted on the front of a 20ft trailer with built up wooden sides and a screen type of tarp on the top. When the vacuum sucks up the leaves it will chop them up a time or two(not into specks). The vacuum is so strong it will pack the leaves into the trailer and will be extremely heavy when full. To unload, connect a chain to a thick pallet. Put the pallet at the front of the trailer and run the chain along the bottom. Hook the chain to your tractor or mini x and pull out to remove the leaves. Make sure it's a thick pallet or something similar, incase it breaks then you have to unload by hand. Some people will use old tires instead of a pallet for that reason.
That’s a good tip!!
104,850
That sounds like a really great idea in a pinch. What kind of leaf vacuum did you use?
Reactions: sharp
