P1000 Cabin Comfort Kit + 2020 Honda Pioneer 1000-5 LE
hibbert
65
81
CR
Hey,
I have a 2020 Honda Pioneer 1000-5 LE that looks like this-
2020 11 09 13 30 12
How can I tell if the Cabin Comfort Kit has been installed or not?
I'm under the impression that all models of 2018 onwards have it, if thats true - how can I verify?
Thanks in advance for your answers!
208,722
Hey,
Thanks in advance for your answers! @t
Doesn't mater if it has it or not, it doesn't work. I installed a fan under the seat, that helped, but I finally bought the Quick Shield from @trigger, it's works!
ODAMO
ODAMO
1,274
3,421
Ohio
Which is? I took the seat off and didn’t see anything that looked like the cabin comfort kit. Only a couple thinner than the sides plastic pieces under the seat then open engine compartment
Those thinner plastic panels create a thermal break because of the air gap which the rubber sheet did not do. Perfect? No. But definitely an improvement
K
Kettlebell1000-5
7
21
Central illinois
The 2022 has the plastic covers and other things that are supposed to be a better solution than the original cabin heat kit.
Wow, I don’t know what it was like before but it’s not good. The center seat and center where seat belts come up is smoking hot. I had my water bottle there and it was too hot to handle after riding for about a hour. From what I’m seeing the dei kit supposably doesn’t fit the model with under seat storage and idrive trans.
JenElio
JenElio
71,280
653,163
Loxahatchee, florida
Wow, I don’t know what it was like before but it’s not good. The center seat and center where seat belts come up is smoking hot. I had my water bottle there and it was too hot to handle after riding for about a hour. From what I’m seeing the dei kit supposably doesn’t fit the model with under seat storage and i drive trans.
Welcome to the club from south Fl
Soooo........POIDH!!😂
Have you looked at the heat shields @trigger sells? They 100% work for heat and some noise......and if you ask the right person they'll say it also cuts down about 90% of the dust........
Now, about you driving trans.........I'd keep that on the DL 😂😂JK😂😂
NTC!!!!
173,860
You can try DIY stuff and spend as much or more just to have it not work as well as one of these. Simple install, no sticky sh** and lasts forever. I don't advertise anywhere else and started making these only to help out Honda SxS members.
TripleB
TripleB
14,353
126,357
Caryville, Tennessee
I drove @Plumber32 2016 pioneer on 4 good rides this past summer. It has none of the updated heat shields. The steam baths would burn the piss out of you. Hottest rig I've ever been in. He won one of your shields at the takeover and his rig will be the ultimate test. If his lazy ass would install it and bring it back to Tennessee.
