P1000 Calling all clay shooters HELP
MuDSlinger
MuDSlinger
204
1,108
Richland, WA
Just purchased a P1000-5. Give me some ideas for shotgun mounts on the clay range. Everything I find doesnt support the 32 inch barrel o/u under my roof. ANY IDEAS , LINKS , PICS.
THANKS , RIDE RED
Reactions: sharp and Plumber32
69,050
THANKS , RIDE RED
I use some of that memory foam. And lay them in there. I see a lot of gun mounts in the rangers that are holding up to 32" but not sure of the make.
Reactions: MuDSlinger
MuDSlinger
MuDSlinger
204
1,108
Richland, WA
Typical Sunday at the range. Got a couple more miles on the P. Come on guys I no someone out there has a gun rack set up for the clay range. Thinking of getting a JEI bed extender and coming off of it with somthing. any ideas
20191103 170627
Swampmonkey
Swampmonkey
149
149
Al
Suregrip gun racks.
MuDSlinger
MuDSlinger
204
1,108
Richland, WA
Thanks Brother !! 99.9 percent of ranges it would be fine, but I was at a NSCA shoot in CO and one of their deligates flagged me because I didnt have my gun in an upright position.
Jimmy-AZ
135
161
Gold Canyon, AZ
I am a NSCA life member and shoot a lot of sporting Clay's. This is a Berreta 682 gold E with 32" barrels and extended chokes. As you can see (vertical) safe and easy access. I did do some modifications (better mouse trap) as you can see with the aluminium plates at top and bottom. If you are interested, I can tell you all the details.
20191111 140004
20191111 135953
Sent from my SM-T837V using Tapatalk
MuDSlinger
MuDSlinger
204
1,108
Richland, WA
I am a NSCA life member and shoot a lot of sporting Clay's. This is a Berreta 682 gold E with 32" barrels and extended chokes. As you can see (vertical) safe and easy access. I did do some modifications (better mouse trap) as you can see with the aluminium plates at top and bottom. If you are interested, I can tell you all the details.View attachment 165489View attachment 165490
Thanks brother I shoot the same gun with the trap barrel....I was high rib before it became cool ...lol
Working on something now but if it doesn't work out I'll hit you up.
MuDSlinger
AKA...TNClayBuster...until they closed the shotgun forum
