T
Yup.. it’s the toe alright... probably the camel.There is no adjustment unless you buy aftermarket arms. Have you checked the toe? They are known to be way out and not set from the factory.
I am a camel whisperer!Let @JTW play with the camel while you adjust your toe in and you will be good to go.
Probably toed out.View attachment 146885 My 2018 P1000-5 is eating the inside tread on both front tires. Just over 400 miles total on this thing. Is there any camber adjustment? I called the Honda dealer and was told there’s nothing they can do. He said bring it in and he’ll turn the tires around so the tread is on the inside. Really?!
Oh ok.. you want picsWe don't really need to hear about what you do with your camel @JTW.
