K
With all the bolts loose cant get enough adjustment to correct the alignment. windshield does latch but its not square when lining it up with the roll bar/ cage. Driver side needs to come up about an inch or passenger down an inch.
the gas strut brackets which i will call the main brackets as far as i see are not adjustable. . Once i get the top and bottom clamp on the roll bar, cage theres no more room to adjust. Its a solid bracket from there. Slop in screws isnt going to give me an inch adjstment needed. Lower windshield is down on hood as far as it will go.
anyone else run into this?
