Can't answer your question, but it's common courtesy to introduce yourself and post a pic or two of your buggy (even if it's been a year since you joined!)
I run the cfab arms with fox shocks and 30x9.50R15. I have rear OE axles. My front are rhino 2.0 with the high lifter steering stops. I had the Rhino axles on front before the cfab arms. So far I have not had any issues.
I enjoy mine so far. My arms are the cfab with 3" lift. I had 28x10-14 SuperATV Intimidators when my wife and I rode the 2023 TakeOver. After being home I swapped out to a set of 30x9.50R15 Achilles Desert Hawk MT. I will not be using the Achilles on the trail. They were purchased for an at home use tire that are DOT LT rated. I am in the process of getting a new set of 14 trail tires soon. I can't decide between 28 and 30 for my next set.
