Check engine light 9 flashes
Gambled22
Gambled22
14
25
Ft.lauderdale
I have a 2015 pioneer 500 , just got it and I love it, was riding a few days ago and my check engine light came on, 9 short flashes, can someone help me narrow down the problem. Hoping it's something simple
Gambled22
Gambled22
14
25
Ft.lauderdale
Thanks but I got it figured out after doing some research, found it was the IAT sensor, took some mass airflow sensor cleaner and sprayed it down and the light went away!
Reactions: JTW and Tflynn
gatorguy
gatorguy
98
404
53
Florida
I had my CEL come on today with the same 9 short flashes. I looked at the sensor and instead saw the wires were cut off right at the base of the plug. Anybody have an idea how to take apart the plug so I can reattach the wires?
IMG 1651 zpsfs3mhbak
66,879
This is a 6 plug
But is it like this 3ccc6cc011d3be891e966132830cc9fc
66,879
Ya.
OK. I hate those. I had one laying around. Let me find it.
gatorguy
gatorguy
98
404
53
Florida
10-4, I was a little worried it'd be hard.
66,879
OK. First the gray cover comes out.
Use a pic and stick it in that hole and gently pry up.
64262a9020fdcdfd1f09d9dc8ec87dc7
66,879
Now you will see the pin catches inside.
Pin catch is where the red dot is. Lift it up and pull the wire out. Each pin has its own catch.
115d6128030a2bc93d56e81d14c40ab0
gatorguy
gatorguy
98
404
53
Florida
I got the gray piece off and the rubber grommet inside the plug but nothing else seems moveable?
IMG 1656 zpsgl0t4s2j
66,879
I marked the pin catches.
In this image they need to go down.
Both are black and plastic.
Reactions: gatorguy
66,879
Tip.
Work one wire at a time. clamp the wire with a pair of vice grips.
gatorguy
gatorguy
98
404
53
Florida
Victory! Now how in the world do I get new wire in there? lol Those crimps are tiny
gatorguy
gatorguy
98
404
53
Florida
I guess I just cut off the old wire and solder the new wire in its place? Thank you so much for your help. Just another reason to love this forum! Sometimes it saves you money lol
