Is it just showing dashes? Regardless, I'd check to make sure your battery is good.Hello everyone. I have a 2017 pioneer 1k. The display that shows the park gear and reverse isn't showing. And also engine light stays lit. But no code flash. Any help would be very appreciated
Ah, okay. Good luckIt'll start any gear with foot on the break. It'll start park neutral without brake. And I've ran through every ground. Might be a dealer trip in the future 🙄
I think your on to something, a couple years ago I figured out I could start it in gear as long as the brake was pushed, then it started doing weird things, like rpms fluctuating wildly after a restart? I quit doing that, now in Park with brake on it tries to do the fluctuating, take foot off the brake normal RPMs All this started before I installed the back up lights?Do you happen to have any kind of reverse lighting? Starting in h would keep you from crossing reverse in the shift gate. If you back feed a ground into the back up harness it can freak things out.
No sir no reverse lighting at all.Do you happen to have any kind of reverse lighting? Starting in h would keep you from crossing reverse in the shift gate. If you back feed a ground into the back up harness it can freak things out.
