P1000 CV temps after a 15 mile ride
DDDonkey
@Hondasxs
Well I did a quick ride this morning 45-50 mph for 7.5 miles and took the portal and CV temps after the ride. The fronts were all in the 80 degree area nothing over 90 degrees but the rear was a different story. Just for reference I just installed the Rhino 2.0 axles in the rear and used an infrared temp gun about 4-6" from each component measured.
Going from the pass side to drive side the temps were as follows;
passenger portal -84 degrees
outer cv - 176 degrees
inner cv - 224 degrees
rear diff - 304 degrees
inner cv - 190 degrees
outer cv - 140 degrees
driver portal - 85 degrees
Then after a 5 min cool down I rode home the 7.5 miles (15 miles round trip) and took it again and the end results are this;
passenger portal -90 degrees
outer cv - 174 degrees
inner cv - 275 degrees
rear diff - 294 degrees
inner cv - 195 degrees
outer cv - 150 degrees
Driver portal - 92 degrees
Now the last 3/4 of a mile was at 25 mph in my neighborhood and that's why I think the rear diff cooled down some.
I think that I will be changing the rear diff oil every 600 miles from now on, any thoughts? I was surprised that the portals stay as cool as they did.
66,869
Thanks for collecting this data. Some of our findings were just as rough.
Do you have a lift kit with the superatv arms?
Reactions: BWAF and JTW
DDDonkey
I am running the 814 shocks and they gave me 1.5" of lift, but no bracket or spacer lift. I was really surprised on the rear diff temp even running in turf mode.
Reactions: BWAF
Hawk53
Hawk53
479
610
Alberta Canada
@Hondasxs
What range was the unit in? Turf, 2wd,4wd ect ?
Reactions: BWAF
43,057
Not that it helps with the 1000, but both my 700 and 500 would/will get too hot to touch on the rear diff and inner cv's. And they sure as hell wouldn't move like a 1000.
Reactions: BWAF
Yup.. I’ve been trying to figure this out for a couple years. I don’t have portals but just a HL lift and SATV a arms. I found the stock axles ran cooler than SATV axles. But eventually, did the same. I just put my 2.0’s in yesterday and will see how they do. I’ve been on rides and taken temps from multiple machines and mine is significantly hotter than others. Both inner and outter cvs. My diff is typically cooler than the cvs.
Reactions: BWAF and TripleB
60,372
@JTW has yours always done it? Ever tried swapping the rear hubs from another machine that doesn't heat up? Maybe something is tweaked just enough to put it in a bind but you can't see it?
Reactions: Mopower58 and BWAF
I first noticed mine when I put on the SATV axles.. it got better when I swapped back to the Honda axles but they eventually did it too. It’s both sides on the rear and innner and outter cv’s
  • Wow
Reactions: BWAF and Ragnar406
60,372
Weird. Maybe you're just too fat? Hopefully the 2.0's resolve it.
ToddACimer
ToddACimer
Pioneer 1005-2
3,673
15,526
Oshkosh, Wi
Were you having issues in 2wd lock or turf mode?
Reactions: BWAF
1Ktrailrider
1Ktrailrider
183
282
Pennsylvania
I wonder what the difference would be in 2wd lock? Other manufacturers also have heat issues with turf mode. They even came out with a turf mode delete for the Polaris general. Also wondering how the aftermarket axles make more heat. Seams like the heat is simply transferring from the diff. If that theory is correct then A stock axle will stay cooler because the material is more dense, where a lighter material will transfer heat faster. I do some road riding from time to time but I don't worry about it. But an interesting topic.
