P1000 Did my first oil change- 2 things.
steve_whiteside
55
108
San Diego
  2. Other Brand
Thanks for that oil change video- super helpful to include even the torques.
1. My oil changed at 92 miles of moderate use. I drove it pretty much like i intend to drive it. It seemed like a waste. The oil looked brand new and so did the filters- not even dark. Maybe I should have driven it harder...
2. I have the UHMV full skids from Trial Armor. I made quite a mess even though I drained the one tank first. At one point it was like a rain forest of oil dripping from all of the seams. My Bobcat skid steer comes with a flex hose that fits into the drain hole permanently. You pull the 8 in hose out; point it towards the drain pan- take off a cap and the out drains out. Is there anyone that sells such a braided line for pioneer? How about those guys at RB3?
Anyway, pretty happy with my buggy and pretty happy with the forum. That for all of you guys chiming in.
steve
On the oil change... 100 miles or your hours whichever comes last. You’re just making sure any shavings are out.
As for the oil change being a mess... there’s really not a good way to do it. I have a one piece skid I made. One of the advantages of the 3 piece skid is you can just take out the one plate. But I make a cardboard funnel to help minimize the mess, but the reality is... it’s just a terrible design for doing neatly. Particularly, when you go to change the oil filter. But if you stick a lice of thin cardboard like a coke box or I’v even split a plastic bottle. It makes life easier. Even more so if you’re doing it on a lift.
Pilotadam
Pilotadam
326
735
Pell City, Alabama
steve
I like the idea of the hose connected to the drain plug. My inboard mercruiser has the same thing. When it's time to change the oil I pull the hose out the drain. Plug and put it into an old 5 gallon gas can to drain.
Russ989
Russ989
22,642
147,257
It’s messy, I have some oil absorbing pads that I slide underneath the engine/trans. It helps catch the extra so it’s not dripping from the skid for a week. JTW is right, just a poor design.
Reactions: Mudwing
Dasmoeturhead
1/4" Air Ratchet and a 10mm socket will zip that skid plate off in no time.
Reactions: Russ989
Russ989
Russ989
22,642
147,257
That’s very true, but once you upgrade to a trail armor it’s a PITA to take that section off.
Reactions: steve_whiteside
K
ken1200
5
Elkins, WV
Upload 2019 12 25 11 8 34
Reactions: Mudwing
Dasmoeturhead
Yeah I can see that. I actually take the entire skid plate off. I also change the sub- trans oil when I do the eng/trans oil and filters. I like spending some quality time with the Pioneer in my shop with some good tunes, and a beverage. I do a good wipe down on the under carriage. I know I am wasting oil changing the sub trans so often, but it's only like
1.27 quarts of oil.
The whole process to me is therapeutic.
I rotate the tires as well.
HappyCamper
59
103
Wyo
I found the biggest mess is from the oil pan plug. At the angle it's on it shoots a bunch of oil on top of my factory skid plate. To remedy this, I just got out the good ol' Dremmel tool and made the hole in the skid plate longer and a bit wider and problem solved! Oil now drains into pan as it should not all over my skid plate to later drip on my garage floor for a week!
Vikes79
Vikes79
SKOL!
11,768
114,098
South Dakota
  2. Talon X4 LV
I have this on my Ariens ztr and other small engines.
I’m curious if any one has done this on their rigs yet.
I have to put on my trail armor skid plate yet. I guess I’m changing oil too!
Reactions: CID
