P1000m3 Did you ever had this problem? Engine stop running for no reason
BleuetVoyageur
Alma Lac St-Jean QC, Canada
I just bought this side by side Honda 1000 es 2017 three places. On my first ride after few miles the engine stopped running for no reasons and I re started it no problem and the same thing happened more and more. Brought my side by side to the dealer and he found that it was a faulty injector, they changed it.
Went for another ride but after quarter of mile I stopped to clear branches, engine was running idle, I've try to move and the engine started to sound poor in gas and stopped and didn't want to re-start.( Gas tank was full) Lucky I wasn't to far from home. I'm starting to don't trust my side by side.
Anybody who met this problem, please let me know if your dealer found the problem and where it was coming from.
Thank you.
Reactions: BWAF
BWAF
BWAF
I get paid to pass gas
8,863
42,472
Carthage MO
Thank you.
Mine did it once a year ago at 100 miles 1500 on now hasn't done it since
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Thank you.
Its possible it's been sitting a while and the fuel system is gummed up. Which would foul the injector. Make sure you are using non ethanol fuel and pour a can of sea foam Into the fuel tank.
0860silverado
954
1,834
louisiana
Ditto on the sea foam. That stuff is voodoo magic crazy good.
E
Ericthered
Eric The Red
271
522
Sparks, NV
As your unit is new... check all the ground wires. Mine acted up with 24 miles. Found obviously loose ground wire by oil filters. Checked all others, there are 4 that I've found, one little loose and the engine one barely on. Tightened up and cleaned. Haven't missed a beat since. (250 miles) And it's not hard. lift bed and pull seat bottom. You can see and check nearly everything on the 1000-3. Good luck and hope this changes your mind about Pioneers.
