P1000 Dipstick under front seat ? 2019 1000-5
Russ989
Russ989
22,601
146,863
What is the dipstick under front seat? Mine isn't showing any fluid on the dipstick.
It’s your sub-transmission, this should be what you’re looking at.
194CF099 7CAA 4CDC 972F D54697109A10
Ohio4x4
Ohio4x4
I brought the dishwasher
1,496
15,042
What type of fluid does it hold? Should it be not reading on dipstick when engine is cold?
10w30 honda gn4 is what I use in both my engine and sub trans. It should be on the dipstick.
Reactions: TripleB and Isaiah
t-bear
t-bear
NE OK
Oooof! You should be adding oil if it does not show!
ETA - Check oil when cold with dipstick NOT screwed in, just sitting there. Yes it is your transmission oil. Yes it is the same as your motor oil =
Honda GN4 10W-30 Motorcycle Oil - Gallon
t-bear
t-bear
NE OK
Glove box. Some have found it underneath rt front seat. Pull latchat middle of seat.
But take our advice. Sub trans is dangerously low!
