P500 Distance between P520's tires
T
Terrynm
Canada
I'm expecting my new P520 to arrive next week and I'm planning to build a ramp to load it in my truck. I know that the distance between the outsides of the tires should be 50", but could somebody tell me what the distance is between the insides of the tires? Thanks!
Reactions: TxDoc
270,903
To be safe your ramps should be 18"-24" wide each. A maximum overall width of 60" fits in most full size trucks tailgate openings. So 60-48 = 12" center gap or 60-36= 24" center gap depends upon width or ramp track. Either will work for a P500.
Reactions: Terrynm and trigger
173,923
I was going to suggest going wide as well. Don't want to be walking a tight rope with a 1000lb brand new machine.
P
pappyo
597
2,400
OEM P500 Width at 50in. Pair 10in wide Tires = 20in (. 50 - 20 = 30 ) approximate inside width.
After market widening products will change inside width ( wheel offset & A-arms . )
14in to 16in width ramps seem to work well & are easy to store. ( length should be directly related to Rise ( truck height)
Vary Important to have a good GRIP Material for the Tires to Grab.
I line everything up & on the ( trailer or truck - for repeat use ) Permanent Marker for ramp location more than 1 vehicle use different colors. ( comes off with WD 40 ) or a dab of paint comes off with thinner.
Honda Red
Kubota Orange
KEEP CLOSE WATCH only the Left ( drivers side ) the Right will take care of it self ( If tthe SETUP is done Right the 1st. Time )
If We can put these through spots with only 1in.or less clearance at 20mph. ( a 2x4 on Edge Should also work ) oop's ONLY at 20mph though.
