DIY Workshop Stuff
11,304
83,934
After seeing @JTW new toy and reading the “Bears Tinkering thread”, thinking a generic tread for DIY Workshop and Woodworking stuff in this Off-Topics section would be an interesting catch all spot. There’s some really skilled members here and hoping to see projects like his.
My project today, a router table-table, to make use of some shrinking workshop floor space. Everything has to be on wheels for when the (475cc) SxS comes inside.
FE25D8A0 3710 4F24 86E8 68B788AF1DEA
Gorms
Gorms
110
448
Mass
I wish I had more time to tinker, seems like I end up fixing broken chit in my free time.
Today's mission, diagnose which u joint on my truck went out. Found one on the double cardian out on front driveshaft so yanked it and soaking in PB blaster for tomorrow.
20200226 210417
Next weekend is changing the oil pan, ran something good over and ripped a little weep hole in it.
Then its changing windows in house, replacing some lolly columns in basement, and when the weather clears up a bit start swapping frames on our old 12v plow truck. Maybe swap in the compound turbo setup I've been putting together.... Never bored!
11,304
83,934
Cabinet router bits arrived and first attempt for practice with scrap wood. 18 painted doors for office shelves are planned with hidden hinges so a hinge jig may be in my future. Wife doesn’t want raised panels so that makes it easier. Tips welcome.
B89D51A3 1F15 45CA 974F C5E49AD8077E
11,304
83,934
Really like the safety of the Rockler coping jig with their fixed block for end cuts, so made an thick oak insert block as a outside edge hold down for wider stock. Keep those fingers safe.
078764B6 B47B 4005 9DF0 D98C8798D349 A16B6167 00D8 4C15 ACAD 8D8F0A6CA0C3
NTCPrezJB
NTCPrezJB
President of #NTC
100,023
894,307
Canton, OH
Cabinet router bits arrived and first attempt for practice with scrap wood. 18 painted doors for office shelves are planned with hidden hinges so a hinge jig may be in my future. Wife doesn’t want raised panels so that makes it easier. Tips welcome.View attachment 187220
Looks good to me
11,304
83,934
A square tip. Found a use for those HF bar magnets with 2 metal framing squares. One one top of overlapping framing square sides. Those magnets are pretty strong like an extra pair of hands to prevent slipping during clamp set up. Red brackets confirmed angle.
1655B398 6DF3 4FA1 937E 16456F3C70CC 555CDEF8 1E55 460A AE7F F1A5495EAE4E 75AB561C FE69 49FD A2FE DBC829EAC71F B1AE4DE8 87D3 442F 8DE6 B9F83E6124B2
11,304
83,934
My table saw fence is crap for holding still, so attached a old handle to a HF magnetic bar. Pretty strong. Don’t know what kind of metal the magnet is as it resist drilling in a drill press.
D99D0975 83E2 416E BF29 A3ED5B1762B8 2F4A292F 7E81 4FE4 9407 B31433447794
NTCPrezJB
NTCPrezJB
President of #NTC
100,023
894,307
Canton, OH
11,304
83,934
Making the last 4 of the 16 paneled doors for the library built-in shelves. Practicing Social Distancing by working in the garage. This week its wood and glue vs SxS bolts and grease.
40ADD82E 1870 4116 AF2A E263D1F43D9D
11,304
83,934
I‘ve been painting with an air compressor for years and took a shot with the larger HF Avanti HVLP unit. 4 gallons thru it so far and pleased, gun parts disassemble easily for cleaning. Sprayed syrup thick Bonding/Primer without thinning it. Just finished 1st of 2 of Cabinet Paint top coat.
8885E2A4 1C7F 4C5E 9EE5 AAA9087563AE
I picked one of those up a few weeks ago to use with my new compressor. I have a few projects I am going to try to spray all at the same time.
Gorms
Gorms
110
448
Mass
I'm jealous, looks good! Never been much of a finish carpenter/cabinet builder myself though I find it interesting.
Week one of staying home was productive for me. Cleaned garage enough to pull the old Dodge in and start disassembling, took 2 days just to clean and reorganize.
Saturday was a good day to tackle the main beam under our kitchen floor. Not exactly fun but could have been worse. House was built 1786, and the kitchen may have been shortly after. Still has hand hewn posts and main beam in crawl space in that section. Main beam needs replacing eventually but I was able to sister up the bad section with an 8x6 I had laying around. Welded up some support columns that will work for the new main beam when that time comes. Beats stacks of rocks I suppose.
20200328 163030
Sunday and today I was able to start ripping the truck apart. Ultimately I have a roller with a bare shell of a cab, no wiring or dash etc I need to swap everything over to. Got most of the wiring harness disconnected out of engine bay, removed a/c lines, rad, intercooler, driveshafts, exhaust, crossmember. Tomorrow I will drop transmission, hopefully pull motor. I am a lot slower than I used to be.
20200330 200402
Gorms
Gorms
110
448
Mass
Got the motor out and started stripping it down a little bit. The old cab mounts were shot so it made pulling the motor out interesting, could have used another inch of two of firewall clearance.
I didn't plan on pulling the head or anything, but it is a lot easier to do it now so might as well replace head gasket. Head studs, injectors, compound turbos are in the works as well.
20200403 225343
This thing was rusty, had my doubts looking at the exhaust manifold bolts, but with some persuasion none of them broke, amazingly.
20200404 220126
Next will be finish pulling injection pump, head, and clean up the block. 20+ years of work has left it nasty.
11,304
83,934
So now finishing up the duplicate shelving insert for the opposite left side of the room. Trying to decide to orient it mirrored or reversed. Any thoughts from the SxS Interior designers? Regardless, getting alot of practice for future shop cabinets.
4E0478AA 7B70 434B 88D1 806542517255 1B66BAD3 7BF7 48DB B819 FBCE10D6535D 05E7F0F0 66A6 4E64 8FFB 84BFE514156C
NTCPrezJB
NTCPrezJB
President of #NTC
100,023
894,307
Canton, OH
JenElio
JenElio
63,932
600,470
Loxahatchee, florida
Reactions: Mudder
Similar threads
