P700 Do I need relay for this Light Bar?
G
Greg1881
14
25
Montana
My Daughter got me a Alpena Trektec Light Bar D17-P for my 2016 Pioneer 700, but of course it does not come with an On/Off switch, extra wiring or tells me whether I need to install a Relay. So I am a little lost. Specs say it has a current draw of 4.85A@12 Volts and Power of 58.2W.
Can I install this directly to the Battery with the Red Power wire just having a fuse and if I can what size fuse should I use?
If I need to install a Relay can you tell me what brand and type of Relay I should get. I live a ways out from a town so Ebay, Amazon the Club Store would be best to purchase from.
Last, Any suggesting on an ON/Off swith with wiring I could use to mount under the dash?
Thank you
Greg
Pic
115,288
Should do a relay. What kind of switch panel do you have?
If dont have one, its recommended for other things u might add. This one works well and just wire up the lite
Limited-time deal: Auxbeam 6 Gang Switch Panel BC60, Universal Circuit Control Relay System Box with Automatic Dimmable On-Off LED Switch Pod Touch Switch Box for Car Pickup Truck UTV SUV Boat, 2 Year Warranty, Blue https://www.amazon.com/dp/B08RRV197G?tag=sxsweb24-20
115,288
I do not have a switch panel. Thinking to just drill a hole in the dash with a small on/off switch. Wondering if I can go with a Nilight Relay kit I see on Amazon?
Got a link to that?
Id still do the switch panel. You’ll thank me later with kisses 😘
NHMO
  • Haha
Reactions: CID and Smitty335
silvertrd09
silvertrd09
261
1,446
Texas
First off, that Auxbean 6 gang switch panel that Remi linked is sweet! I'd do that cuz you can add more stuff later. If you just want one switch on the dash you shouldn't need a relay. 16 gage wire can handle 10amps at 12volts. And you could easily splice in an inline 5 or 6 Amp fuse. I am running 4 led lights on Pockets with no relay. One is a 6 led bar the other 3 lights are tiny. I my have used 14ga wire though, I'll have to check. If all 4 lights are on at the same time it's probably less than 6 Amps total. I used 30amp rocker switches from autozone. From the battery I ran + and - to a bus bar in a electrical box. Then out to the switches and lights.
Attachments Downloadfile 3 Attachments 2 20230821 194333 D3 1
66,813
As long as you fuse it with a good switch you don't need a relay.
Most carling switches can handle 15 amps (20 rated).
Relays are always a good decision tho.
