P700 Door hinge bolt size
insanetreefrog
insanetreefrog
51
140
Lowell, AR
Hi folks, I'm new to the forum. I have a 2021 700-4 Deluxe, and am working on replacing the bushings in all 4 doors. I tried using a torx t-40 bit to remove the hinges, but to no avail. It stripped out. It has a little play in it, but a torx t-45 is too big. It's crazy tight from the factory.
Did anyone else run into this issue, and what'd you do to get these bolts out?
Thanks!
Reactions: Backwoods
WagginTail
WagginTail
1,577
5,827
SC
My 2014 700-4 has socket head/allen head bolts. Removed mine the first time with a 3/8 drive ratchet.
Headhunterf100
Headhunterf100
60
106
Virginia
  2. Do not currently own
my 2020 is also allen head bolts/ believe they where 6mm my be wrong though.. dont hold me to it
Reactions: Mudwing
Mudwing
Mudwing
36,959
306,672
The Mud holes
I’m pretty sure they are hex sockets not torx. 6mm sounds about right. Use penetrating oil. Mine were hammered on there. Had to re tap threads passenger side. 😎
178,298
Have taken mine off twice and swore I'd never do it again. Yeah, nothing fits them right. When you find the one that fits there's still some slop in it and like @Mudwing said, they're torqued super tight!
Reactions: Mudwing
insanetreefrog
insanetreefrog
51
140
Lowell, AR
Quick update here. @Headhunterf100 was right; for my 2021 Pioneer 700 the bolts need a 6mm allen wrench. Had to use a heat gun to loosen up the crazy glue they put on the threads at the factory.
