Hi folks, I'm new to the forum. I have a 2021 700-4 Deluxe, and am working on replacing the bushings in all 4 doors. I tried using a torx t-40 bit to remove the hinges, but to no avail. It stripped out. It has a little play in it, but a torx t-45 is too big. It's crazy tight from the factory.
Did anyone else run into this issue, and what'd you do to get these bolts out?
Thanks!
Thanks!
