P1000 Door panel screws
kjw83
kjw83
61
30
Madisonville KY
Does anyone have a pic of the screws that hold the door panels on? I’m wanting to add the color panels to my base model 5 seater.....also the size of the screw would be helpful. Thanks
W
wyodlr
147
209
Cody Wyoming
the dealers here just use the push pins , the same ones that hold the fenders on
kjw83
kjw83
61
30
Madisonville KY
Well my panels finally showed up and I was shocked to see that the screws used to hold them
to the door have a blunt end on them. For some reason in my mind I was expecting them to be like a self tapping screw.....can I just drill a hole in the door for the screw to thread in to? Hoping someone with a deluxe model can help me out......what does your doors look like with the panels removed? Is there something else I need for the screw to thread in to?
Did they not come with nutcerts?
McMaster-Carr
Reactions: pct
No they did not.....I have a base model P1k5. I only ordered the door panels and the screws bc i was assuming that’s all I would need.
The link I included should be the right size
Reactions: pct
Ok....so I just drill a hole, insert the rivet, and then thread the screw into it?
You will need a tool to seat the rivet as well. McMaster Carr has those as well. Don’t buy one from Harbor Freight or Northern tool they are utter crap.
McMaster-Carr
Reactions: pct
HondaTech
Honda just wants you to mudclip them on. They'll be pretty loose after while, I'm sure. I'd probably just nut sert them like mentioned.
kjw83
kjw83
61
30
Madisonville KY
That one is utter JUNK I went through 3 of them PDQ(warranty)
Spend the extra $ and get the McMaster Carr one you won’t regret it.
What is junk about it? I’m not one to use a rivet tool very much....as long as I can get this one job done I’ll be happy
It comes apart , if you’re only gonna use it once it’s fine.
