Hello Matt, this could be several things, here’s where I’d start.Hello people of the same interest. My name is Matt and I have a 2009 big red S×S that I am having issues with. It's getting fuel to the injector, the spark is strong and consistent but it won't start. Please help.
Thank you for that quick response "Russ989" I appreciate the feed back. Unfortunately I have been over the thing twice now. Cleaned everything , looked from every angle. No damage visible. The valves where the first thing I checked because I heard little ting to it but they were barely out. I dont believe its getting fuel to the piston. Its injected but I don't no how to check those and got the machine without manual.Any feed back is much appreciated. Its actually my grandfather's side by side and he is like a kid. Chomping at the bit. Thank you.Hello Matt, this could be several things, here’s where I’d start.
Without any other info, it’s hard to diagnose what may be wrong.
- Check all of your grounds and connections
- Check wiring harness for rodent damage
- Check valve clearance
- Check compression
Here’s the fuel injector Part on Amazon. I’d pull the injector and make sure it’s getting gas. You could also give the intake a shot of starting fluid to see if it would fire.Thank you for that quick response "Russ989" I appreciate the feed back. Unfortunately I have been over the thing twice now. Cleaned everything , looked from every angle. No damage visible. The valves where the first thing I checked because I heard little ting to it but they were barely out. I dont believe its getting fuel to the piston. Its injected but I don't no how to check those and got the machine without manual.Any feed back is much appreciated. Its actually my grandfather's side by side and he is like a kid. Chomping at the bit. Thank you.
Yep. What he said. 👍. I’d pull the injector and make sure it’s getting gas. You could also give the intake a shot of starting fluid to see if it would fire.
Amazon.com: Unlimited Fuel Injector For Honda BIG RED MUV700 09-13, CRF450R 09-10, FOURTRAX RINCON 680 TRX680 06-14, PIONEER 700 SXS700M 14-17, TRX680FA 13 16-18, TRX250X 16, TRX700XX 08-09, Replace 16450-HN8-A61: Automotive
Buy Unlimited Fuel Injector For Honda BIG RED MUV700 09-13, CRF450R 09-10, FOURTRAX RINCON 680 TRX680 06-14, PIONEER 700 SXS700M 14-17, TRX680FA 13 16-18, TRX250X 16, TRX700XX 08-09, Replace 16450-HN8-A61: Fuel Injectors - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
