P1000 Dual voltage gauge setup
Kisssofdeath
Kisssofdeath
55
128
Greer, SC
I see where some use the single gauge that displays voltage from both batteries and I see some setups that have a gauge for each battery. Is one way more accurate or reliable over the other or is it a matter of person preference?
Reactions: rtn001 and Biteme
Dirtstiffs-1000
Dirtstiffs-1000
1,655
6,030
hondasxs.com
Accuracy? Quality? Water resistant?
They work ok.
There are better dual gauges available now outside of the Azon guage, most of us have.
About 36 bucks.
20191026 170832
JenElio
JenElio
73,136
665,815
Loxahatchee, florida
Welcome to the club!
I'm pretty sure its more of a personal preference and how you want your switch panel to look/function
Kisssofdeath
Kisssofdeath
55
128
Greer, SC
Thanks everyone for the feedback. I thought it might have been personal. So far "electrical related" all I have bought is this panel from Professional Bull Riders, some call it PBR. :rolleyes::) I'm 100% sure I will use this.
1592012443036
For $159 I'll probably get the 5000 lb Badland winch from Harbor Freight. :eek:
Here's my week old ride. I'm going to try and not go crazy with mods like I did with my P650.
IMG 20200611 200749
Here is my long gone old ride. Photos were taken several years back right before selling it.
20160101 214353
20160101 214359
20160101 214443
20160101 214537
20160101 214523
Sowie
Sowie
31
55
Bunnell, Fl
The Blue Sea voltage gauges are made for day or night visibility. They are for marine use but if you get them I added some silicone around where the metal prongs come out the back to keep any water out. Don’t ask how I found this out. Got mine at West Marine.
Formula1
Formula1
160
264
SE Missouri
I have their USB and fuse block. They do make good stuff but I don't think they make a round dual voltage gauge.
Kisssofdeath
Kisssofdeath
55
128
Greer, SC
I'd like to have this but this place is sold out. Wanted it for the same reason as Formula1 mentioned. Would be happy buying two, even for that price.
P1000_DLux
P1000_DLux
Its Only an Opinion Relax
Belfair, WA
Flip Switch
Battery Isolator
I installed a variation of the PBR switch plate that included the cup holders and I recommend drilling the mounting holes slightly larger to accept the Honda plastic push pins, the plate is rock solid and it also makes it easier to take in and out vice the rivets they provide.
As it pertains to the double battery because of the isolator the read out it pretty good and I installed a seperate dual read out gage because the one that came with my plate was a single and it seems to work really well.
Check out my thread "So it Begins..." because I have added alot and there is so much more that could be added, good luck not moding its so hard not to.
Also welcome to the club.
Formula1
Formula1
160
264
SE Missouri
I got two of mine from 50 caliber racing, or something like that. The winch switch I'm looking to replace but can't find one I like under $40.
D0AC1B8B ADF8 4B8A B1F4 B6258500D934
Reactions: rtn001
Papaandhistoys
Papaandhistoys
134
227
Backwoods of northern Michigan
I believe I have separate relays for the light bar and side lights. I installed a stinger and separate fuse panel to run all the accessories through with second battery.
I’ve done the second battery,fuse panel, stinger and on off on switch install (THANKS TO THIS AWSOME SITE),I ran two led,48watt cubes in the back and wondering if I need to put them on a relay. I have them wired to my fuse panel now.
Reactions: rtn001
Yeah IP67 rated for the front only. They assume you are mounting it in a boat dash where it will get splash from the face. You have to seal the back.
Reactions: rtn001 and Sowie
Sowie
Sowie
31
55
Bunnell, Fl
If I remember correctly all the led lights that I bought from the Hondasxs store here all came with relays.
Reactions: rtn001
