P1000 Engine Oil GH4 or HP4S
Which Honda oil will you use
  • Total voters
    5
  • Poll closed .
mobil makes hondas hp4s and gn4 oils
That's good info, now I'd like to know if they used group 3 or 4 oils for the synthetic. Do you have any more info?
bigc
bigc
432
128
hp4s is group 5 no idea on gn4
I'm curious where you get that info? It is labeled to be compatible with other Dino oils which group 5 usually isn't.
I was just doing s little research and it appears that ExxonMobile lost the Honda oil contract a while back and now ConnocoPhillips makes Honda oil.
ghost
ghost
993
1,874
BC
I will add this note, I did change oil in the differentials and noticed a big improvement in gear noise. I used 75-140 and added Lucas stabilizer.
140 is quite a bit higher viscosity than the Honda recommended 90. Do you add enough Lucas stabilizer the bring it down or am I over-thinking it?
Can I ask what brand oil and what Oil / stabilizer ratios you use?
Reactions: Delton
Buckrocker
Buckrocker
99
124
Rock, WV
I have been debating this issue as well. Talking to the dealer Friday and he suggested 1st oil change based on hours of service not 100 miles. He said he felt the break-in was not completed and said you would have better results based on hours on the engine. I didn't argue but was doing the math in my head. That could be a lot of miles!
Interesting?
75-140 isn't actually a 140 weight oil. It gives the protection of a 140 and flows like a 75 weight when cold.
The idea IS to thicken the oil to reduce noise. Now, it will cause an increase in parasitic power loss in the drive train but not noticeable at all.
The lucas oil additive is very thick and "clings" to the gears for very good wear protection. It will also provide some cushion to reduce noise. I used 50% OEM oil and 50% lucas on the pioneer 1000
On the P700 I used Mobil 1 75-140 and lucas additive.
I hope his helps. I never had any adverse affects. Now, my friend owns my old pioneer 700 and still drives it with the same oil in it. It's approaching 1000 miles and no problems. Also, many others have done this same thing.
Joe
Reactions: ghost
ButchersHook
ButchersHook
167
332
I put in HP4S after the first oil change and I will say, it starts almost instantly. first thing I noticed before the oil change was the amount of cranks it took for it to start, I believe this was discussed on another post.
Someone mentioned Hondas fired based on oil pressure. I believe I added 6 qts 8 ozs. It was @-5 the other morning and the 1000 fired right up sitting in the garage, drove it to work where it sits outside all day and it was 2 cranks and it was idling.
When I had the 700 I was amazed the difference the Amsoil made for cold start warm-up/shifting.
With the HP4S in the 1000 I am amazed how it changed the starting.
Was the oil a tad on the low side to begin with? Or did the HP4S make that much of a difference? My machine gets started and driven everyday of the week same as the 700 did so I take alot of mental notes on temp changes and their effects on the machine.
Reactions: joeymt33
ofrcboy
ofrcboy
507
589
Oregon
Thats interesting, When I brought my machine home it cranked a couple times to start. I checked all fluids and added a couple oz. of engine oil. as it was a little low and now thinking back adding oil did seem to make it start faster. Anyone else have ideas on this?
