drfubar
TheDonFather
I have the same set with soft doors, soft mid panel and split windshield on P 1000 5. I took pipe insulation/foam and insulated the gaps in front and on the sides between the ROPS and the roof. Also did the ROPS between the doors and window. Used a couple of pool noodles on the gap between the middle roll bar and roof. It's not air tight by any means but cuts down on a lot of cold air. Working on a solution to insulate the gaps around the front doors.We rode Royal Blue the week after Christmas.
We rode to the Top of the World around 8pm,
with 14 degrees outside. I have the split
windshield, hard top, soft sides & back.
I was more than comfortable with just
a fleece pullover. I did remove my home
made engine heat liner from under the
seat, & I was comfortable for the day &
nights we rode.
Add the soft doors & ride all winter.
John
Edit to add: The only thing that got cold
was my left leg resting against the door.
I would occasionally shift in the seat to
minimize that contact. Some sort of padded
covers would be nice for cold weather riding.
The worst cold air I have now is coming thru the shifter holes. Put on the air dam and it improved it but still a lot of air thru them. Might have to get the shifter cover the guy on here sells.
Stays pretty comfy until you run it up to about 40 mph in 10 deg weather.
Exactly.. the wind coming from behind kept blowing down into my face...Looks good Doc! It'll keep the wind from messing up your hair
Is it easy to remove for summer riding?
This the Honda mid panel? I'm thinking about adding on to my 5seater.Installed yesterday this panel. Not sure it's going to do anything except keep me a little warmer in the winter. I like it, well made and easy to install.
View attachment 61227 View attachment 61228
https://amazon.com/gp/product/B014UA8PVG/?tag=sxsweb24-20This the Honda mid panel? I'm thinking about adding on to my 5seater.
There is a difference between 3 and 5 seater mid panels.Thank you Doc.
There are cutouts for the clamps. Velcro goes around the bar. The metal hooks go above the rear seat belt.I know this is an old thread, but how are you guys installing the fabric rear panel with the roof clamps?
Thank you Doc.
