Factor 55 Prolink XTV Winch Hook - $75 shipped
A
aggietke00
Houston, TX
New and Unused Factor 55 Prolink XTV winch hook.
The ProLink XTV allows UTV and ATV winch owners to replace the conventional winch hook with a safer and stronger shackle/D-Ring. Winch hooks can cut and fray recovery straps and often allow strap ends to escape during typical loose/tight cycles of a winching recovery. Screw pin shackles do not allow strap loops to escape due to the secure screw pin attachment. The ProLink XTV does not require splicing and is compatible with steel cables or synthetic ropes up to 5/16 inches.
IMG 0112
Reactions: russknight
