Fan stays on all the time
stbknox
My Dad has a Pioneer 700-4 and he washed it yesterday, when he went to start it today the fan immediately came on and the malfunction light is blinking. He lives 6 hours away so its not something I can look at, just trying to search online and find an answer but having no luck. Has anybody seen this issue and know what might be causing it. He has started it multiple times and the fan always comes on immediately and the light blinks. He has unhooked the battery but that didn't work. He changed the oil and filter after this happened, also checked coolant which was fine.
Any ideas or suggestions on this? Thanks
68,409
I bet the wire on the thermosensor has came loose.
Stand by and I'll look up where it is.
stbknox
Ok thanks, I managed to pull the owners manual up online so I will be looking for it also.
68,409
Havent tested this on the Pioneer. But on other Honda ATV's if the ECT sensor is bad or lost connection the fan will default to "ON"
  • ECTsensor.pdf
stbknox
Hondasxs said:
Havent tested this on the Pioneer. But on other Honda ATV's if this sensor is bad or lost connection the fan will default to "ON"
Thank you very much for taking the time to look this up. I notice there are 3 sensors on the attachment, is there a certain one he should check or check them all in order?
