P1000 fuel injection warning light came on
selfguided
5
arizona
got close to 1300 miles on machine driving the other day warming light came on and locked my machine to an idle turned it off then back on and light hasn't come since running better than ever taking it in to dealer to see what code was hoping it was a glitch first issue I had with my machine is that the fan connector wasn't plugged in from factory other than 2 small issues couldn't be more happy with my machine
66,868
Hopefully just a one-time thing. Some have reported grounds not being tight causing similar problems.
Update us on what the dealer finds.
jfreak
10
10
PNW
I had a loose connection at the engine block near the starter causing all kinds of weird stuff. But with 1300 miles I'm sure you would've noticed other symptoms.
In to hear what the dealer thinks caused it.
selfguided
5
arizona
dealer called and said nothing wrong with it sometime of low voltage code but they couldn't find nothing wrong
Reactions: sharp
