Ground Plane for Ham antenna
Bandman
Bandman
130
460
Hayden Lake, ID
I’m installing a ham radio antenna (Comet SS-608SBNMO) on my 22 P1000/5 cage with an Axia mount.
8A7A3222 FCAA 435D BC78 9C5740820628
I know it need a ground plain so wonder what would be the best way. Can I run a heavy wire (#8?) from the mount to the frame or do I need to sand through the paint on the mount and frame?
Thanks!
Killer223
Killer223
265
530
i use that same mount with my setup with a no ground plane antenna and one with my pioneer with a normal antenna, no issues. i can still get 15+ miles simplex. don't think you'll need a grounding strap.
check your swr's and move mount to get the best results. i had to lower mine about 2" for the best swr's with my antenna.
Killer223
Killer223
265
530
I’m installing a ham radio antenna (Comet SS-608SBNMO) on my 22 P1000/5 cage with an Axia mount. View attachment 363939I know it need a ground plain so wonder what would be the best way. Can I run a heavy wire (#8?) from the mount to the frame or do I need to sand through the paint on the mount and frame?
Thanks!
best all around dualband antenna i've ever used was this one.
if you type this into amazon it'll come up.
B075TZV4RR
it doesn't get you the range like a 1/2 or 5/8 wave will. but for using dualband at the same time. it's been perfect!. the the one currently on my pioneer.
My talon has. B01559XYHQ
in the center of the roof when i'm not carring a bag there, else i use the mount you posted on the passanger rear pillar with my previous antenna mentioned.
Bandman
Bandman
130
460
Hayden Lake, ID
Thanks everyone for yout input.
i figured it best to go with a ‘no ground plane’ antenna so I wouldn’t have to worry about it. I also need a shorter one with a spring so I went with a Browning BR-136 Tri-Band Antenna 22”. I’ll let you know how it works…
Dasmoeturhead
I use a dual band 2m/70cm mag mount antenna, mounted on a L shaped metal bracket bolted to the roof. I've had this setup for 6 years, and it works good.
Bandman
Bandman
130
460
Hayden Lake, ID
I appreciate all the information i recieved here so I wanted to post my completed project. I installed a TYT TH-8600 with a Browning BR-136 NGP antenna.
I was able use the standard radio mount by reversing it and enlarging one of the mounting holes to attach to one of the mounts for my SuperATV windshield mounts,20221202 132101
20221202 140548
20221202 141451
20221202 163051
20221202 163009
