70,198
Cheers!
15536467545661001874669321626446
106,161
In the continuing saga and the slow drip n drain of the honey. After crushing all the honey filled combs, I strained it through some cheese cloth and a colander into a large stock pot and let sit for two days. Most of the honey has separated and drained into the pot but there’s still a fair amount in there, so now the colander is setting at an angle and I formed a drainage area within. Hopefully with this method of forced angled gravity draw, it will separate more of the honey from the crushed combs. The excitement that is my life.....stay tuned for the next exciting excursion into the flow of mo’ Golden Deliciousness!
F5A04B99 DB00 4B68 89A2 BAF0AC009457
22758C33 5B71 4D0D AC48 EB3B925DB62C
6D79BA9F 2226 4DAC BDEB 59FC5E32615A
E88F1A53 30F3 4F3F A81F 27F981CC15F2
210,940
Tankless suck up here. Ground water is a lot colder here. And they don't put out the gpm more than 2 people require.
Talking gas Tankless, what the ambient temperature of the water coming in, we have 45 in the dead of winter, with a Rinnai RU199i 5.0 gpm will supply two showers nonstop until you run out of money. What is the ambient temperature of your in coming water?
70,198
About 36 -38. You run a shower don't turn on the clothes washer.
70,198
We usually require about 90 deg rise. And our water here is 23 g hardness so if you run out of salt in the softener you need a service call.
MOVE SOUTH ours is 62 year round....15grains and Tannins but 2backwash filters for hardness and tannin work just fine. I could get more GPM if I had better tools to work with PEX. My filter plumbing works and is leak free but I’m not posting a picture of it to get judged and shamed.
70,198
Same reason I wont pull the hood on my pioneer in public anymore. If it doesn't leak or in my case the lights stay on though 4' of water were good, anything more is either a waste of time or for bragging.
