BrophyCreek
BrophyCreek
522
3,252
New Richmond, WI
Cheers boys! Ca677f58ba150892c458ec7d148bc5e5
Sent from my SM-G781V using Tapatalk
BrophyCreek
BrophyCreek
522
3,252
New Richmond, WI
But....Houston, we have a problem. Went to upgrade my 16 to 22 tie rods, but found that the stud on the outer joint is only 10mm. On my 16, they are 12mm. The inner is the same on both and the OAL looks right. Must be wrong outer ends?2fd6f857e95adf5172ef98e65d870f0b
BrophyCreek
BrophyCreek
522
3,252
New Richmond, WI
But....Houston, we have a problem. Went to upgrade my 16 to 22 tie rods, but found that the stud on the outer joint is only 10mm. On my 16, they are 12mm. The inner is the same on both and the OAL looks right. Must be wrong outer ends?View attachment 405895
Update, I just looked up the part and they are for a P500. Ughh! Dang parts guy got me again!
TripleB
TripleB
21,175
183,983
Caryville, Tennessee
I'm not saying they ain't the ones for the 500 but the newer tierod ends are a smaller diameter stud. They probably are the correct ones. You will need the correct nuts to complete the install.
BrophyCreek
BrophyCreek
522
3,252
New Richmond, WI
I'm not saying they ain't the ones for the 500 but the newer tierod end are a smaller diameter stud. They probably are the correct ones. You will need the correct nuts to complete the install.
Yes! I am missing both my nuts, LMAO! Took me way too long to figure that out. @ToddACimer had said the same. But, I mixed up the part bags (inner vs outer) and chased my tale on Partzilla like a dumbass. As logic would have it, the P1K inner part # starts with the same first five as the P5 inner. But, I was looking for outer, so...Yup...Derp
Fatsquatch
Fatsquatch
Approved Member
121,623
1,013,933
Hidden
Phuckin’ parts guy anyway! 🤣
Nomo
