Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,543
Central Iowa
Layover in Atlanta. Why doesn't the airport have a Twin Peaks? 142df4d2693b27b08b9379adb96ecc99
Well s***!
IMG 1897
IMG 1898
The Cummins almost left me stranded. Water in fuel light has been on for 2 months but until this morning has ran fine. Died on my way to work but hit the water drain and back under way. Changed fuel filter and found this beauty. Never seen something so bad. I wouldn't suggest this to many other engines
Reactions: R-Lamm and Eltobgi
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
Well s***!
View attachment 59430 View attachment 59429
Rut roh!
Reactions: CumminsPusher
Well s***!
I wouldn’t suggest it with your motor either... dads did similar only without the light. Bottom of his fuel tank was nasty too. Ended up having to replace a pump from it. He’s careful where he fills up and uses additive semi-regular but a 2001 with 70k miles is bound to have a little algae.
Well s***!
I hear premium 93 removes water, algae, and any other contaminate from a diesel tank right @Plumber32?
Hey I love Plumber as a brother and most with a diesel has at one time f***ed up or was close. I pumped 10 gallons into the Dodge before I realized. But like R I didn't start it:)
popeye
popeye
3,275
14,644
kapowsin, Wa
Knock on wood after 14 years of owning a few different diesels, have yet to been there or done that, but helped a buddy drop the tank in his truck after his wife toped off the tank with gas when the fuel light was on.
70,273
Well s***!
Wow!
70,273
What causes this? @CumminsPusher ?
Reactions: Plumber32
GPR1500SC
GPR1500SC
861
2,427
North East MO
  2. Talon X LV
Putting gasoline into your diesel was a old school anti gel trick before the new dryer ultra low sulfur diesel came along 5 to 10 gallon to the hundred depending how cold of a area you planned to run in.
Now days you pay two or three times more a gallon and it says Power Service, Howes, or Schaffers on the label.
