The install is pretty easy. install the two clamps up top, similar to the ones that come with the roof and windshield. Then raise the bed and there is 5 bolts that you loosen that attach the seat back to the frame. Slide the panel down and do any necessary adjustments for the perfect fit. Tighten the bolts back and attach the two side pieces using the snap clips. The panel comes with two brackets you have to drill a hole into the main piece of the panel. The bracket is short and doesn't line up without a bunch of pressure on the panel and even then the threads are garbage. the washers that came with the bolts are too small also.
