Multi Help! Broken Battery Terminal
OldToby
OldToby
109
539
29C19367 3DD8 47B8 A7AB EBE01F2FE1D0
i just got one of those little 10AH 12v batteries delivered from Amazon, and the negative spade terminal is broken off flush with the resin whatever-it-is packing stuff. Amazon is sending me a new one and tells me just to keep the old one, which (apart from the broken connector) is perfectly good. Does anyone have any ideas re fixing this and making it usable? Since it’ll probably never be up to a lot of vibration, I can’t use it as a starting battery for my old genset as planned, but I thought I might use it as part of a small solar setup to take camping, for charging gps, cellphones, etc. Thoughts, anyone? Thanks!!
Reactions: sharp
322,690
View attachment 93863 i just got one of those little 10AH 12v batteries delivered from Amazon, and the negative spade terminal is broken off flush with the resin whatever-it-is packing stuff. Amazon is sending me a new one and tells me just to keep the old one, which (apart from the broken connector) is perfectly good. Does anyone have any ideas re fixing this and making it usable? Since it’ll probably never be up to a lot of vibration, I can’t use it as a starting battery for my old genset as planned, but I thought I might use it as part of a small solar setup to take camping, for charging gps, cellphones, etc. Thoughts, anyone? Thanks!!
Short of digging it out some, hoping there’s still enough plastic there and soldering a wire in place, not sure because it’s so close to the body. I wouldn’t recommend that though.
“I knew a guy” lol, that used a soldering gun on side of battery to fix a crack and it worked even with acid leaking out. But that was stupid
OldToby
OldToby
109
539
That packing stuff looks/acts like some kind of epoxy, so I don’t think I can melt it out w/a soldering iron or a little torch. I’m thinking maybe I could dremel it out enough to get room to solder a wire to it, then attach a male spade to the wire. A wire would also help with vibration issues.
322,690
If had a dremel that would work. I imagine that case is thick. Put on safety gogs and have shower running lol. I don’t like throwing away usable stuff either so I’d do it. Not sure how flammable the fumes are but “the guy I know “ says the acid was toxic as s*** when it the soldering iron hit it. Boy be careful buddy. I really hate suggesting anything dangerous but I do know where you live lol
OldToby
OldToby
109
539
Well, you’re right about the whole “dangerousness” thing. It’s a sliding scale for sure. I was just thinking that I could take it over to my buddy’s house and get his thoughts on the subject. We’d start with a couple of shots of cheap vodka, then the ideas would start to flow!!
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Return it
Reactions: sharp
swsebek
swsebek
2,854
5,835
pa
My self I would keep it around to just test stuff when I needed 12 volts. But wouldn't use it in any rides. I would run a self tapper along side of what's left just to get it.If acid is leaking out of that spot. Use water to clean and epoxy or RTV sealant.
OldToby
OldToby
109
539
My self I would keep it around to just test stuff when I needed 12 volts. But wouldn't use it in any rides. I would run a self tapper along side of what's left just to get it.If acid is leaking out of that spot. Use water to clean and epoxy or etc sealant.
I like the self-tapper idea. I wasn’t planning on using it on anything that would vibrate it. I could always use it for fishing, run a little switch inline and use it to set off caps.
Backwoods
Backwoods
35,252
357,962
Douglasville ga
They gave you another battery your not out anything take it to parts store get ten bucks then your ahead . Don't lose your eyesight over a battery. Being cheap has a limit.
