P1000 Help finding a part
1Ktrailrider
1Ktrailrider
183
282
Pennsylvania
How do I locate the part# or link to the DCT sub harness? I'm looking for the small section of wire harness that's under the bed that plugs into the shift motor, shift solenoids, and what not
20210213 102403
Reactions: Lady01 and TxDoc
HondaTech
#15 is for the front of the sub trans, it includes the gear (TR) sensor, neutral switch connector, speed sensor connector and the 2 connectors thst hook it to the man harness.
The shift motor connector is made into the main harness. The small sub harness your referring to only contains the 3 oil pressure sensors, and internal solenoid connectors. Im not aware of anyone whose tracked down just the shift motor connector yet. Without it in front of me, i cant remember if it fits other things, besides the Talon.
There is a engine sub harness for the Talon, that i believe has that connector on it. But retail is over $130.
It could be a easily sourced connector, but id have to see one to identify it.
