I got my fans installed under front seat and the 60mil rubber liner from front of bottom seat to top of back seat. The heat issue is much better but now the dust is the problem. I have full windshield and full top but the windshield has vents in it and that helps to play around with air direction. But it seems like to me a lot of it is coming from lower gap of back doors and the holes between rear seats where the latches are. For the gaps under door would adding the rear fender flares help that because it looks like it would keep dust from tire from just shooting into that hole. We’ve only had it about a month so I don’t think the fans I added made it worse, just think this is first time we’ve rode it while it was as dry as it is right now. I have some different gasket material coming so I can try and seal up the gaps some but curious if I’m even looking in right spot. I don’t have a rear panel and would like to keep it that way if possible.
Thanks
Thanks
