Oh, wise knowers of all things large and small about Pioneer 500s!
I have a zipper problem one of the Falcon Ridge soft doors on my P500.
The zipper pull slider (yes- there is a name for the piece) moves freely to a point in a curved portion of the door and then stops.
When I examine the zipper with a magnifying glass from both sides, I do not see any mis-aligned teeth jamming it. Tugging hard on both inside and external pulls with pieces of paracord looped on does not work. Placing a wood wedge and gently tapping it did not work. I can pull the zipper away from the spot and it engages the teeth below perfectly.
Any ideas/ suggestions of what to do next? I tried a dab if white lithium grease with no luck.
I’m afraid to apply too much force (if such an idea exists) and make it worse.
Thanks!
Thanks!
