P500 High pitched squeal when it warms up
Tom_C
Tom_C
158
473
Virginia, USA
Finally getting out this year to ride a bit and notice a high pitched squeal, or singing, from the front end. Sort of sounds like a tea kettle. Haven't popped the hood yet but sort of expect a coolant leak or the radiator cap leaking. Anyone have that happen?
  • Haha
Reactions: Remington and ChadD
futzin
futzin
3,946
29,199
Kentucky
Haven't heard of that before . . .
Reactions: ChadD
113,404
Hard to tell you what a “squeal” sound is or if we've had the same without physically hearing it. If you are married, you should understand this 😂🤣
So take a vigea of it, load it to LubeTube, copy and paste it here. You’ll get better results
Reactions: ChadD
Tom_C
Tom_C
158
473
Virginia, USA
I came home today, but going back next week. I have a windshield and have to remove it to get the hood off. I was tied up, else I would have opened it up. When I'm back up there I'll have a peek, and/or take a video if I don't see anything immediately apparent.
Reactions: ChadD and Remington
113,404
Without physically hearing it, throwing darts now.
Rear brake got mud, dust crud in it?
Wash the hell out of it then try it. Only real way to check that off the list
Reactions: ChadD
Hello_Darkness
Hello_Darkness
221
899
Just to the right of nowhere
So maybe it doesn't apply to the P500
Buy it might help
Screenshot 20240811 103940 Drive
Mopower58
Mopower58
CST is the Best!
76,865
689,954
Crystal Springs,Ms.
Possibly a rock hung up in the rotor? Try backing up and applying the brakes hard 2 or 3 times. If it’s a rock in a rotor it will usually back out with this method.
Tom_C
Tom_C
158
473
Virginia, USA
I don't think it's anything in the brakes or drive shafts, but until I am back up there I won't say it isn't.
It starts when it gets hot, and when I'm moving. Slow down or stop and the noise stops... which could be indicative of something is the brakes or shafts, so I won't rule it out but it doesn't "act" like it's that. It's def coming from the front, under the hood as far as I can tell.
Reactions: Backwoods
113,404
Dont forget to hit “reply” or tagg the person @Tom_C your replying to so they get a notice like you did or they may never know you replied if they dont come back to the thread every now and again or it may take alot longer to get your issue resolved 😉
Tom_C
Tom_C
158
473
Virginia, USA
I was replying to the 'thread' because there was more than one person who commented. I was saying that when I am back and can answer the questions better then I will do it. But, I'll use the reply option, if that's what you would like me to do.
  • Haha
113,404
Hay man, Im just trying to help thats all. Its was not criticism to you.
I looked back on your old posts before i responded and almost all of them you didint hit reply or tag the person you responded to.
If you just forgot So be it. But it looked like the ladder and I was just trying to help so u got answers and more promptly. No need to get bent lol. Its not “what Id like for you to do” at all. Again unsolicited advice, its your thread do what you want. 👍🏻
  • Wow
Reactions: Tom_C
