P1000 HL Lift 2022 Pioneer 1000-3 deluxe
rudyeng
109
554
Florida
Hey guys I want to let you know that the HL 2.5" lift fits the 2022 pioneer 1000-3 deluxe. No trimming. I pulled out the 4 plastic plugs and lowered the plastic cover. Installed the lift then reset the plastic cover.
Gained about 1.5" in the front and 2.5" in the rear.
Best of luck !
Rudy
P1K5Dave
P1K5Dave
2,220
8,332
Petoskey, MI
What plastic plugs are you referring to?
Let us know what you think of the change in your ride with the bracket lift. Did you go to bigger tires too, and if so, did you run them before the lift?
Reactions: Lady01 and JenElio
rudyeng
109
554
Florida
I went with the 30" cryptids. I have not tested the SXS off road but I believe I removed most of the rubbing with the 2.5" HL. I also air down the cryptids to soak up some the trail riding, rocks, holes, etc. See pic of plug below
IMG 20220629 212442284
Best of luck !
Rudy
113,565
Best of luck !
Rudy
Those are push pins used in about 1 million areas of the pioneer 🤣
Best of luck with your bracket lift.
hope you have a good relationship with your dentist lol
