P500 HMF exhaust and fuel controller
Kkettlebell
Kkettlebell
114
475
Nova Scotia
Who’s running a combo like this? What model pipe and controller? Was it worth it? Will the ones for the 14-22 Foreman work?
177,960
I am. There's no muffler out there that's a slip on so it's a little involved. Then I'm running the Dobeck AFR+. Also added a K&N air filter and ran dual pipes for the snorkel to open it up. It definitely runs cooler. As for power gain, I notice a difference in mid range but that also depends on how you tune the Dobeck.
177,960
Kkettlebell
Kkettlebell
114
475
Nova Scotia
Thanks bud
Kkettlebell
Kkettlebell
114
475
Nova Scotia
I wonder if this one could be modified to work?
59533FEA 9884 47EF A265 8A3F1EF3B3AE
Kkettlebell
Kkettlebell
114
475
Nova Scotia
I’m thinking the newer Foreman exhausts should have the bung already in for the O2 sensor
The Green Goat
The Green Goat
2,156
15,932
Ohio
Stumbled onto this old video I made. Don't know if it'll give you incentive to do it or pass on it.
Tell me about that remote shock reservoir mount.
177,960
That sounds fantastic…did you cut off the cat and then welded on the slip on?
No slip on available. Cut the exhaust including the cat off and weld in some pipe. Also had to drill in a bung for a second 02 that came with the Dobeck AFR. Dobeck will run plug and play but can also be adjusted. Messed around with it when I first got it and dialed it in for what I think is optimal midrange power. No sense messing with top end, your speed is limited anyway. And with the granny gear in the P5, it didn't make any sense to mess with the low end.
177,960
The Green Goat
The Green Goat
2,156
15,932
Ohio
