Honda 1000 Switch Plate Volt Meter Wire Harness 0SA30-HL4-100
G gkozak New Member Mar 15, 2019 21 9 3 Ottawa Ontario Ownership 1000-5 Mar 16, 2019 #1 Reactions: sharp
RedFred1 Well-Known Member Aug 4, 2018 301 619 93 North Carolina Ownership 1000-3 Mar 17, 2019 #2 https://powersports.honda.com/documentum/MW01/0SA30-HL4-100.pdf Typical as it has no wiring diagram... did you install it as specified or are you trying to change things around? Sounds like you need a good meter and a wiring diagram. FredD
Neohio Beast of the East Lifetime Member Supporting Member Club Contributor Dec 22, 2016 13,243 63,654 113 Painesville Ohio Ownership 1000-5 Mar 17, 2019 #3 Reach out to @STRATOSMICRO ? I know he makes kits to tie into these. I bet he knows the pinouts and how to get you what you want. Reactions: RedFred1
G gkozak New Member Mar 15, 2019 21 9 3 Ottawa Ontario Ownership 1000-5 Mar 17, 2019 #4 RedFred1 said: https://powersports.honda.com/documentum/MW01/0SA30-HL4-100.pdf Typical as it has no wiring diagram... did you install it as specified or are you trying to change things around? Sounds like you need a good meter and a wiring diagram. FredD Click to expand... Hi, yes all installed as specified, just trying to make use of two vacant circuit ports on the back that have 3 and 4 prong connections intended for either wiper or heater accessory.
G gkozak New Member Mar 15, 2019 21 9 3 Ottawa Ontario Ownership 1000-5 Mar 17, 2019 #5 Neohio said: Reach out to @STRATOSMICRO ? I know he makes kits to tie into these. I bet he knows the pinouts and how to get you what you want. Click to expand... Good point, will ask him
