P1000 Honda 3P Rear Soft Panel
Slowdog
I was considering purchasing a Honda rear soft panel for my 1000P3, but the information listed says that you need to have a front windshield if using a Honda rear soft panel. I was wondering if it was compatible with a half windshield. Does anyone run a half windshield with soft rear?
E
elkguide
3,377
7,964
Vermont
I have both a front and rear solid glass on my rig but what you're describing to me sounds like a sail. Don't think that there would be any way that you could get away with a soft back and a half front.
Reactions: Mudwing
Slowdog
I was thinking the same thing but I see the soft rear being used with a flip out windshield? If the flip out is full open wouldn't that be the same?
YardDog
YardDog
Grumpy ol' fart
617
1,937
Arkansas
I have the Super ATV flip out windshield and the Honda soft rear panel on my 1000-3 and haven't had any issues. I don't keep the windshield full open if I'm hauling azz though because that would truly be a sail in the wind. The rear panel unzips so you can roll it up to let the air pass through if needed. I have towed my rig at 75mph for 900 miles with no damage, but the windshield was closed. I'm sure a half windshield and the rear not rolled up would probably do some damage if you was towing it down the interstate.
Russ
mn
I modified a 1000-3 soft top and a 1000-5 soft panel to work on my 1000-5 I use a half windshield soft doors and just unzip the back panel.
Reactions: YardDog
Slowdog
Thanks for the reply! I haul mine in an enclosed trailer so transporting won't be an issue. It sounds like when I'm cruising around the hills the combination of a half windshield and a soft rear panel should be okay.
Reactions: YardDog
YardDog
YardDog
Grumpy ol' fart
617
1,937
Arkansas
You shouldn't have any problems. Might catch air and hold you back at high speeds, but otherwise you will be good to go.
