Pioneer 1000-5
ENGINE
Engine Type 999cc liquid-cooled twin-cylinder Unicam® four-stroke
Bore And Stroke 92mm x 75.1mm
Compression Ratio 10:1
Induction Fuel Injection (PGM-FI), 44mm throttle body
Ignition Full-transistorized with electronic advance
DRIVE TRAIN
Transmission Fully-Automatic Dual Clutch Transmission (DCT) with six forward gears and Reverse. Four drive modes include 2WD, 4WD, Turf and Differential lock.Dual Range Sub-Transmission.
Transmission Paddle Shifters with three shift modes (standard, sport, and manual)
Driveline Direct front and rear driveshafts
CHASSIS / SUSPENSION / BRAKES
Front Suspension Independent double-wishbone; 10.55 inches travel
Rear Suspension Independent double-wishbone; 10 inches travel
Front Brake 210mm hydraulic disc
Rear Brake 210mm hydraulic disc
Front Tires 27 x 9-12
Rear Tires 27 x 11-12
DIMENSIONS
Bed Capacity 1000 pounds
Towing Capacity 2000 pounds
OTHER
Note Recommended for Drivers 16 years of age and older.
Available Colors Red, Olive
Model Id SXS1000M5P
FACTORY WARRANTY INFORMATION
Duration One Year
Description Transferable limited warranty; extended coverage available with a Honda Protection Plan
ENGINE
DRIVE TRAIN
DIMENSIONS
OTHER
Model Id SXS1000M5P
Duration One Year
