P500 Honda Pioneer 500 -Clutch Spring Kit!!!!!
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
2nd gear start to the floor spins the ripsaws like nothing!!! but sadly have to remove the front case fix the seal put all back to gether adjust the clutch again lol then i can really put it to the test
Reactions: Dp5hunter
Dp5hunter
Dp5hunter
3,056
Hazlehurst Mississippi
minus the oops part start to finish took me give or take 5hrs total
Great job Jak that took a lot of patience and dedication to change the cloche spring. It is bad ass that u can now take of that hard from 2nd guire. I'm shour that with that stronger cloche spring will also extended the life of the cloche dew to less sleaping of the cloche. ;)
Reactions: jak9922
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
better news seal removes and installs from the outside :) yay happy jak now just wait for new one to come
20170226 194109
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
ok just put new seal in and took it for a ride. its definitely different with the stall but it takes off much harder ( harder for the p5) and the shifts are alot more firm im really going to love this the more i ride it
JCart
JCart
895
2,021
Kamloops, BC Canada.
Nice work Jak! Question in terms of slow idling around with P5 in gear, with stronger springs clutch engagement is 300-500 rpm higher? Then say loading in back of truck is (up the ramps) easier? The same goes for crawling over logs and big obstacles? Clutch grips harder at lower RPMs too?
Thanks for sharing Jak.
j
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
you have more power on take off think of a stall converter on a drag car it brings the rpms up to have more power when you take off this is just a mild stall but definitely helps and is 100% noticeable
Reactions: Dp5hunter and JCart
Dp5hunter
Dp5hunter
3,056
How much did you say the kit cost?
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
Thanks Jak. Well now I know what my next purchase will by.;):cool:
its a huge pain in the a$$ seriously you also have to be careful because the clutch adjust plate will fall off it just sits on the shift shaft
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
also the the dowl pin for the oil pick up will come out very easily you have to be very very careful of that
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
not trying to scare you away from doing it lol
Dp5hunter
Dp5hunter
3,056
I got u brother. Bot I will not be doing that install, it will be done by a person that has more knowledge then me about that intricate type of project. Bot I thank you for the wournings ;)
